RCU Forums - View Single Post - 3W70 engine problem
Old 06-07-2007 | 03:54 PM
wyldman
Default RE: 3W70 engine problem
the ignition is mounted on rubber gromets and has 1/2 inch of clearence underneather and is mounted on the side of the engine box out in the open.
It has plenty of cooling air but if it's going bad then it will get hot inside and start acting up.
I was hoping someone else has already had this happen and new the solution so I don't have to buy and ignition system if I don't need to.
thanks
Wyldman
