RCU Forums - View Single Post - Shifting Problem (Video) Jumping From 1st To 2nd And Back??
Old 06-07-2007 | 07:00 PM
ENR_Kyle
Default Shifting Problem (Video) Jumping From 1st To 2nd And Back??
ok.. Here is the video:
http://s16.photobucket.com/albums/b3...003_rename.flv
and here is the problem.. as you can hear is kinda hesitates, sounds like its hitting second the back.. but when I give it alot of gas you can hear it shift at a higher rmp?.. when its on the ground it does the same thing but you can not hear it shift.. Any ideas?..
BTW. got the OS A3 plug and it runs like CHAMP.. It will run and idel all day at under 200..
How does the smoke look, prety good, running rich enough?..
