RE: Leaving the elec ignition switch on.....problems ??
I accidentally left mine (3W brand) turned on for many hours. The battery still had a pretty good charge. they don't draw much when the prop is not spinning. but if you leave it on for days, I suspect it will drain the battery down flat.
