RE: Evolution 26GT - Difficuty Priming
I guess I was vague in my question. My problem is at the Carberator. The fuel fitting on the carb makes a 90 deg bend and is pointed toward the rear of the engine. About 1.5 inches after the carb fitting the fuel line is getting overheated and gets burned, right between the engine block and the muffler. I am using a beam mount, maybe that makes a difference??
Joel
