RCU Forums - View Single Post - Flying in reverse (apparently
Old 06-09-2007 | 06:33 AM
Premium2000
Default RE: Flying in reverse (apparently
The test glider is the definately the way to go. Thanks for making that point Bruce!
Ok here is a crazy idea, sort of a Hail Mary pass if everything else fails. How about a steerable engine? Think outboard boat engine. I would think that +/- 10 degrees would be enough. The mechanics would be easy enough to design, the issue is whether the servo load would be too much. What do you think?
Larry
