ORIGINAL: gregziemba
wait thats the .40 ultimate from great planes right im building one right now im going to be puting a .61 in it. the satio going into the u-can-do. How the areobatic on? can you hover with it? Thanks for the help!
I run a 100 Saito in my .60 UCANDO and love it. Unlimited vertical and 20' takeoffs. I use an APC 15-4W prop.
One good thing about the Saito is that the UCANDO gas tank is mounted over one inch too high in the fuse which floods out most other engines. (it can't be esaily moved without chopping the plane up) The Saito loves it there but make sure it's not hydrolocked before you put the electric starter on it. Good luck.
