RCU Forums - View Single Post - Which are long lasting engines ABC or Ringed???
Old 06-09-2007 | 08:37 AM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Which are long lasting engines ABC or Ringed???
but why is it said that O.S.'s L.A. series is less powerfull than FX or AX series?
Because they are timed to have lower performance, has almost nothing to do with the bushing and air bleed carb (other than the smaller size of the carb) They are designed to be lower power and cheaper. The bushings and air bleed carb make it cheaper, the timing and small carb size give it lower power. However, they are good torque motors. The control line modelers like them for that reason.
