RCU Forums - View Single Post - take off
Thread: take off
Old 03-03-2003 | 03:42 AM
Highlander
Default take off
Does the plane have ground speed ? if it performs on the ground then it not likely to be the prop , but in some form or another it is a control surface or CG problem , what type of control rods do you use , ? if they are flexing at speed , even though you have full stick input they may not be at full deflection
Highlander
