Everything I need to know about Propane
Kevin_w thanks for the response on the powermax. So when you buy a Jetcat is comes with the onboard cannister and the valve and fittings for refueling that cannister?
I've got a MW-54(directions say propane or the mixed gas such as powermax) and I'm just wondering what equipment do people use for refueling their onboard propane cannister? And also some safety tips on the refueling process.
I see BVM sells a trigger type valve for refueling, anybody using that?
Wren sells equipment for refueling but its the european equivalent, need to find the US equivalent.
I also see that BVM sells a propane cannister that look like a spring air retract air bottle with the proper fittings for propane.
Jerry
