RE: Raptor 50 engine alignment problem
You changed both the pinion and the main gear?
If yes, then I'd look at that 3rd bearing block because I built my Titan with 8.7 gears and didn't have any fit or alignment problem, if you have to start drilling out frame holes then something is wrong.
