RCU Forums - View Single Post - World models spot on 50
Old 06-09-2007 | 08:17 PM
DUCATI996
Default RE: World models spot on 50
Flight Report:
This is the Best Flying Airplane I have at the moment. Great Flying caracteristics + the 61 is perfect for it. The plane will end up being nose heavy. Total dry weight was 6.0 lbs but I had to add 2 oz in the back to get it to the recommended CG (117mm). I had to use the Spinner they supPLY + A Top-Flite wood propeller to reduce the nose weight. DOWN SIDE: Some of the decoration came off on the first flight (triangles on Stabilizer, left side) which is not a big deal, but really sucks. The Landing Gear is EXTREMALY heave, I will replace it with CF once I find it. You have to through away the screws they supply for you to use as axles (thats a no-brainer). I did all that my heart let me handle on the first two flights ( Knife edge are rock-solid no coupling, Snaps, Square Loos, Triangle Loops, All the snaps you can imagen).
Great Flying Airplane, I will start looking at 120 in a few weeks.
Best Regards
