RE: sts questions
Unless you are a pro driver need a couple hundreds of a second off your lap times I do not see much need in modifying a high performance engine. If you have a sports type engine then I recommend up grading to a race type engine. The only thing I see in modified engines is being smoother through the RPM range.
