Another simple engine trick would that you could try is to add a .005 shim under the piston sleeve
BTW, Valves in a 4 cycle engine are open at the same time. This normally occures between the exhaust and the intake stroke for about 10 - 15 degrees of rotation. This is called valve overlap.
BV
