RE: Lanier Mariner 40 MKII ARF 62"
Erratic behavior was definitely the result of water inside changing the CG. Sealing the leading edge will solve that problem. Also, keep an eye down near the tail. If the covering leaks a bit there water can find it's way up into the fuse on takeoff. Just make sure the edges are sealed.
Enjoy!
