RCU Forums - View Single Post - P-60 Temp problem
Old 06-10-2007 | 10:38 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: P-60 Temp problem
Hello,
The temperature you are seeing is the equivalent of an open circuit on the K type thermocouple, so there is also a chance the black data cable going between the ECU and the front of the turbine is bad. Check that first. If a different cable does not fix it, it sounds like you need a new temp probe.
I believe Bob is letting handy guys change it out themselves but you should call to verify, not everyone is comfortable with that type of repair.
Hope that helps,
