RE: SULLIVAN TAILWHEEL ASSEMBLY
For the least amount of binding, center the bearing on the hinge line. If the rudder balsa is soft you can just push the spring wire in. If it is too hard use a 1/16 drill bit. Either way, once the spring wire is in the rudder. Wick some thin CA into the hole followed by some thick CA.
