RCU Forums - View Single Post - BT64EI settings
Old 06-11-2007 | 08:33 AM
joesigg's Avatar
joesigg
Default BT64EI settings
Bax:
Have 64EI in 1/3 Albatross and we can't get it set right following the manual. Running a Zinger 24X8 wood prop []and getting 6000 max. The problem is rapid acceleration. If we idle less than 2300, it dies on rapid throttle increase. Yet it will idle nicely at 1600. Read one post you did on the 43 and you refer to settings to start that are twice those in manual. Is this true of 64 also? We are going nuts trying to set this engine, having stayed withing the range specified by the manual. Has about 1 hr running time on it.
HELP!!
Thank you.
joesigg
