RCU Forums - View Single Post - SULLIVAN TAILWHEEL ASSEMBLY
Old 06-11-2007 | 10:40 PM
shd3920
Default RE: SULLIVAN TAILWHEEL ASSEMBLY
Unfortunately in order to get the blindnuts inside the fuselage where they belong to hold the wheelbracket you will need to cut away some covering to get inside.
An alternative I would suggest is to screw the tailwheel assembly into the fuselage rear with regular wood or sheetmetal screws. Probably #4X3/4 screws would be perfect for securing the assembly onto the fuselage. The sullivan wheel assembly has 4 predrilled holes for attaching so feel free to use as many screws as you feel like using. It would be more secure if you had a lite-ply doubler at the rear where the bracket is gonna screw into but if it is not doubled no big worry (just a little less secure) so use about 3 #4X3/4 screws to hold the bracket in place.
