RCU Forums - View Single Post - Heres my boat (MRP Python)
Old 06-12-2007 | 01:22 AM
evaderstbasher's Avatar
evaderstbasher
Default RE: Heres my boat (MRP Python)
went to adjust the carb, well the lock nut was backing off the entire fitting.. so i took off hte whole fitting, got the lock nut off, when putting hte fitting back on with my hand, the thing snaps in half, with half of the fitting inside the carb body screwed in.. no way to get to it..
Luckily i had another carb that i cleaned up earlier and seems to be working fine now.. i used the body and stop screw from the broken carb and switched it off and it is working perfect it seems now
Now onto the tank problem..
