RCU Forums - View Single Post - axe cp thread
Old 06-12-2007 | 09:40 PM
  #1103
Rotor13B
Default RE: axe cp thread
Are you using the training gear on the heli? This seems to cause vibration which translates through the whole heli. Between that and the slight wobble in the head could be enough to cause the violent shaking your seeing.
You can use DU-BRO No. 2x3/8 socket head sheet metal screws to replace the ones that hold the boom tight. They fit perfectly and can get the boom clamped down tight .
