cg
Depends on what you want to do with it.
I flew mine on the rearmost blue trim stripe on the wing for 3d stuff a little in front of that for screwing around. Admittedly i spent more time with the 3d balance point.
I put my battery above my throttle servo in a tray i built and i put my reciever just in front of the wing hold down bolts
Had a 46fx mounted normally in the cowl, not moved forward or anything else.
Hope this helps
[IMG]img1[/IMG]
