ORIGINAL: REDisFASTER
Pedsaktix! That's the exact look I'm trying to achieve with my GT2! Like the guy above, what wheels/tires are those. Also, I'd like to know your suspension setup for having it that low. How does it handle?
Thanks!
Those are [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXM872&P=7]HPI SS Monster Wheel[/link] front/rear in [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLN12&P=ML]Pro-Line Road Rage II 2.2[/link]. Awesome tires really, I highly recommend those..
Im using the stock FT shocks with red firm spring in the back and silver spring up front, both front and back have 35 weight oil. Then lowered it as low as posible, move the spacers up front in the rear hub to get longer wheelbase and lowered the axel height, nothing really special.
Being lower to the ground I thought its now much easier to drive and much more predictable. I also notice around a turn the back stays flat. Even coming into a highspeed corner and letting off the throttle, it will cost you a little oversteer existing a corner but nothing you can't overcome.
