RE: 1 servo for each elevator half problem
Thanks David. I believe I have mine set exactly as you describe, except I use mix 2. I will have to check the subtrim on both elevator halves. I may change the receiver to a 9 channel and use the ailevator function, although I really don't how that would cure this problem. It actually seems to work the way as a mix so I don't understand how it would cure the hi to lo rate problem. I'm hoping you're right and I have a big difference in my subtrims. Thanks again. It has been windy here and I haven't been able to fly anyway!
Mike
