RE: 1 servo for each elevator half problem
The radio forum seems to be alive and well. It is called..... RC Radios, Transmitters, Receivers, Servos, gyros.
Good to hear that your problem CAN be solved with the 7 channel tx. I have the 6XEA and have to use the Y cord.... am I understanding Dave correctly that when using channels 1 and 5, that the trims and hi rate switch all work perfectly?
One problem a guy at our field had was that when setting his 6 channel JR up that way with 1 and 5, that if he advertantly hit the Gear switch while flying it would cause one elevator half to quit working right, and this caused him a crash that destroyed the plane.
Ernie
