RE: 2 RX batteries
Use 2 battery packs and 2 switch harnesses. Charge each battery through it's respective switch harness. Plug switch harnesses into any 2 channels on the RX, typically the BATT and another unused channel. If all channels are used you can use a Y-harness (one side to servo and other to batt switch) but DO NOT connect both batteries to the same channel slot.
