RE: GMS .76 compression....
Vendetta
This is not an ABC set up.
The GMS .76 has a dykes ring. It will feel like there is no compression when turned over by hand. Compression is acheived by the force of combustion gasses "pushing" the ring against the liner wall.
Run the engine, break it in as per the instructions, and see if it performs to spec. It is almost certain that you should have little to worry about
