RCU Forums - View Single Post - Incidence needs tweaking?
Old 06-14-2007 | 01:13 AM
somegeek's Avatar
somegeek
Default RE: Incidence needs tweaking?
ORIGINAL: Jim Dines
The photo looks like you have "0" downthrust and maybe even a little up thrust? If so, that would account for your symptoms. You might check that.
Jim, are you referring to the wing or engine?
When I removed the reflex, I added 1.5 turns of the clevis on one side and 1 turn on the other side to get the ailerons level.
somegeek
