RCU Forums - View Single Post - Alpha 40 or Arrow 40?
Old 06-14-2007 | 01:35 AM
bigedmustafa's Avatar
bigedmustafa
Default RE: Alpha 40 or Arrow 40?
You live in Oklahoma and you need reasons other than, "more stable in the wind?"
Greater stability and visibility are usually major selling points. The landing gear on .60-sized trainers is often more robust than on .40-sized counterparts. I don't have enough specific hands-on time with Alpha .40s and .60s though, to make that assessment.
I will just say that the only disadvantage to a .60-sized Alpha compared to a .40-sized Alpha is cost. The plane will cost more to purchase, and it will use fuel at a modestly higher rate. If cost factors into your decision, then the Thunder Tiger Easy Trainer 40 super combos are your best value.
