RCU Forums - View Single Post - 2 RX batteries
Old 06-14-2007 | 07:21 AM
bruce88123
Default RE: 2 RX batteries
ORIGINAL: Avalanche2
ORIGINAL: overbored77
Avalanche set both of them up as you would for a single battery (seperate switches etc) then plug one into the BATT channel
and the other into any unused channel. Using this system is good insurance. Please remember to check the CG of the palne after
adding the second RX pack.
Edit: Bruce types faster than I do
thanks guys... are any of you using this set up? is it needed??? and my thumbs work better than my typers too...
From what I read a lot of guys are starting to use dual 6 volt packs on larger DX7 planes with high servo loads. This is to avoid the RX reboot problem they appear to be experiencing.
