RE: Directions for Disassembling/Assembling of 2C or 4C engines for Newbies
If the engine ran fine, but now suddently doesn't, and by not running fine, you mean it seems hard to set the mixture, the engine is always running lean or rich, then it's probably a problem in the carb. Often it's just a bit of dirt or something inside the needle valve or spraybar, and if you just remove the carb, then remove the needle and run fuel through everything, you might wash out the problem.
