RCU Forums - View Single Post - Diff leaking?
Old 06-14-2007 | 06:35 PM
j_blaze's Avatar
j_blaze
Default RE: Diff leaking?
dtsn280z , the shock oil won't make the car come up, the springs do. mozzy said it, you need spacers to increase tension from the springs and raise the car up a bit, sounds like you need about 10mm total to start. Add spacers till the lower arm is parallel to the ground or slightly higher, just eyeball it on a table or something. Push it down and i will rise up.
