RCU Forums - View Single Post - Axe cp tail rotor
Old 06-15-2007 | 07:14 AM
bvillepiper
Default RE: Axe cp tail rotor
The problem is getting the two phillips screws on the tail motor mount tight. The proper phillips screw driver to use is a 2 mm. The screw driver has to fit the screw or you can not get the screw tight. You still should check the tail motor assembly during every preflight.
