RCU Forums - View Single Post - 2 RX batteries
Old 06-15-2007 | 07:34 AM
exeter_acres's Avatar
exeter_acres
Default RE: 2 RX batteries
ORIGINAL: j.duncker
I do not like dual battery systems. There is more to go wrong. Simplicate and add more lightness! Just pick the correct battery size to begin with and install a battery monitor if you are marginal or have doubts. I do this on my helis with digital servos because the current consumption is huge and variable depending on what kind of flying you are doing.
I would rather fast charge between flights than rely on seperate batteries. The model shops will advise 2 batt setups for obvious reasons.
Do you fly giant scale?? (ie 35% or more)
Do you use a single battery in Giant scale planes?
