RE: Fuel system air
Hi David,
You probably do not have air in your system....you are observing fuel vapour bubbles created by the vacuum in your fuel system on the suction side. I have had the same problem with the orbit clunk and I agree with Sandor 100%. We are trying to use these pickups in an application for which they were not designed and are not suitable. Some users a may be able to get away with it with engines that don't demand high fuel flow rates. I have sent you a pm. Hope this helps.
Craig.
