Unplug the motor and then unscrew the motor bolts. Push the motor straight down until the heatsink slides off then remove the heatsink through the larger opening in the frame. Mod and then replace in reverse order.They say it's a clip on sink, But they are aluminum so if you distort it then it going to be loose and trying to bend it back would just make it weak or possibly crack imo.
