RE: Painting letters with dope
I have had some bad experiences with frisket paper. I don't like the stuff. It just doesn't stick well enough for me. I like to use tape, seal the edges with clear and then spray color with an airbrush. The airbrush is a huge advantage because you can mist on light coats of color that will dry to the touch in a few minutes and help prevent the subsequent coats from disolving the tape's glue and bleeding under as you build up the opacity. I don't like frisket paper!
