RCU Forums - View Single Post - 2 RX batteries
Old 06-16-2007 | 05:35 AM
CGRetired's Avatar
CGRetired
Default RE: 2 RX batteries
Allan is absolutely right on. This is not rocket science. The lower voltage battery would be charged by the higher voltage battery.
I use the dual battery dual switch configuration, which is the simplest and safest way to go with dual batteries. I add a volt-watch in a vacant channel and use that to monitor the battery situation before and after every flight.
I believe if you read my post earlier, you would see how this setup saved my Venus II.
DS.
