RE: have you ever over heated your brakes?
yeah done that now, still overheats when i do a lot of WOT passes though, just the way the brakes are i guess, the ventilated disk would eliminate the problem all together because the gases just get vented out of the center of the disk, so even if they do get hot you don't get anywhere near as much fade, and because air can get inside the disk to cool it, when you dont have the braes on it will cool down a lot faster as well.
