RE: Prop Guru's!!...Need Help??
try the Fuji with a 22x8 prop. The sagging is an indication, that the engine is loaded too much by a heavy prop. Once properly run in, the sagging probably goes away, but fot the time being, it is not wise to overload the engine.
The smaller pitch also will slow down the plane better in the landing approach.
