RE: ]§[ Official Team VTX ST1 Thread ]§[
Has anybody broken anything on this truck? That is under normal wear and tear on the track, not mailboxes or trying to jump over houses. I have had a few small issues with the clutch bel coming off and I went through some bells early on. My servos are fine, brakes, all plastics have held up, ams, linkages, everything! Is there a short list of items I should have that are common problems on the track? I did grind away the small gear that turns the rear diff today, the screw was loose on the piece that the dog bone goes into in the rear, yes it has a name. So the gear was just sliding around in there. The crown gear is fine but I'll have to get a new....whatever its called, smaller gear the connects to the dog bone, and then some locktite!
