RE: What motor is this
If you're paying $250, then I agree that I think you're probably getting a good deal for a 50cc engine, even if you have to rebuild the carb and ignition. the manual advance ignitions aren't all that bad, but the CH Syncro spark unit is relatively cheap if you wanted to fix your timing and let the EI do the advancing.
