RCU Forums - View Single Post - servos
Thread: servos
Old 03-06-2003 | 10:52 PM
Hubb
Default 5945's
I have also been using the Hitec digitals for two years. I have had good luck with them as well. I have used them in 3 different 35% planes. I had one 5735 I sent in for replacement - bad motor, but thats the only negative experience I've had. I rebuilt a set of 5945's with new gear sets but that was after 300 some flights - ANY metal gear servo will wear gears.
I currently run one per ail, one per elevator half, and two in a push - pull for rudder on my 35% radiocraft.
on a 1/3 scale Staudacher I run one per ail, one each elevator, and one 5735 pull-pull on rudder
I even run two 5945's and two 5925's on my focus pattern plane.
I feel that they are every bit as good as the 8411, but that has been a widely debated comparison by those that are loyal to both brands.
my .02 cents
Hubb
