RCU Forums - View Single Post - Drifting with Locked Diff in a TC4 (It was okay)
Old 06-19-2007 | 12:05 AM
xDennis's Avatar
xDennis
Default Drifting with Locked Diff in a TC4 (It was okay)
Okay,
So I followed the hype about tightening/locking the Diff to make better drifts.
My current setup is pretty stock, with a few shock adjustments.
Initially, I was like wow, I can snap the rear end out pretty well, especially at lower speeds it made it that much easier to snap out, but then after several minutes I quickly realized that holding a faster drift was a little bit harder as the car slowed down quicker and would almost come to a stop in the middle of the drift.. Okay, well not a stop but you know it would just do one of those 360's which is annoying.
I have to spacers (1 thick, 1 thin) in the rear shocks, and the front shocks I adjusted the rebound rate, I moved them in 2 holes to keep it hard up front also.
What I drifted with the above setup with an open diff I could hold a drift much longer at speeds, but now with the locked diff, it almost prefers to drift very slowly.
PRO: I can drive very slowly
Con: Holding longer drift is a little hard and the Diff made a buzzing noise that I'm not really comfortable with.
I will try to play with some of the shock settings to see if I can change it a wee bit, but so far I'm not a BIG fan of it, It was cool, but I still prefer the open diff setup.
What are some of your experiences with a TC4 drifting with locked / tightened Diffs?
