RE: Throttle Servo HELP!! Weird problem
[/quote]
Yes I do dissagree. A coreless motor cannot be made as rugged as a cored motor. They are not made in larger sizes for that and other reasons. Take a look at a drawing of the coreless motor. Note that the armeture is cup shaped and only supported on one end. It also has no metal core to serve as a heat sink. Its much more likely to burn out if stalled.
[/quote]
dirtybird,
not made in larger sizes? the Hitec 5955 is a coreless motor servo, its the most powerfull servo for an aeroplane that Hitec manufacture in a standard size heat sink case.
And lay off the platitudes please.
Mike
