RCU Forums - View Single Post - prop bolts sheared, engine damage?
Old 06-19-2007 | 05:53 AM
Dr1Driver
Default RE: prop bolts sheared, engine damage?
BaldEagel tells you right. As long as you only blipped it a couple of times, it should be ok. However, I'd start wondering what made it throw the prop in the first place. Backfire? Loose bolts? There's a problem here that needs to be looked into.
Dr.1
