MBX5 crowd pleaser use front hole setback then move them in 4mm on eachside i believe. This body is the best I have found and I
have tried k, jammin, thunder tiger, REVO, HOT BODY's, all used of course, the MBX5 is long. leave on the front wheel well and tape
it off so it stays clear and you can fold it inlater. This will stop all the roost from going inside. Just use the back half. The rear shocks
should line up with the body's shock wells.Do to the longer wheel base MUGAN this body keeps her clean inside. one other thing I did
was move the rear mounts to one centered on the rear shock tower. If done right you will be very pleased.
