RCU Forums - View Single Post - Prop Question!!
Old 06-19-2007 | 01:56 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Prop Question!!
You could put a simple balancer like this together for a few cents. A chunk of balsa or two by four, acouple of single edge razor blades and piece of welding rod with some masking tape to size it up to propshaft size.
If you using a cheap plastic spinner I would suggest loosing it, Instead use an aluminum spinner nut, These look better on a trainer anyway far better.
ID:	707207   Click image for larger version
ID:	707208   Click image for larger version
ID:	707209   Click image for larger version
