RCU Forums - View Single Post - Anyone using 2.5" spinner on UCD?
Old 03-06-2003 | 12:44 PM
coomarlin's Avatar
coomarlin
Default Anyone using 2.5" spinner on UCD?
Originally posted by EdMan
Well
I got the Jet 2.25 120 slot spinner in today. Not a happy camper! :angry: The APC 15x6 will not fit, close, but I don't want to try and force it. A 14x4W will fit. What really ticks me off is Tru Turns web site states this spinner with the 120 slot will fit up to an APC 16x10.........not!!!!!! Has anyone ever had much dealing with these folks at Tru Turn. Think they will make good of this spinner and re-cut it to fit the 15x6 without the recharging me. I'm not very happy to have to drop another $10-15 dollars for this darn thing that should of worked the first time. Thanks for any input on this matter.
Regards,
EdMan
Your Jet 120 will fit an APC 16x10. The reason why is that the lower pitched props have wider bases coming from the center point. The higher pitched props have that sharp initial twist and they are actually narrower than the 16x4. Make sense? Truturn told me that if a prop has a pitch of 4-8 then it is considered a wide prop.
