RCU Forums - View Single Post - Hobbistar with dual aileron servos.
Old 06-19-2007 | 04:04 PM
txaggie08's Avatar
txaggie08
Default RE: Hobbistar with dual aileron servos.
ORIGINAL: horace315
i havent done this to this model but it would be the same. if you are converting it to an eletric a single servo might be a better choice as far as weight goes.but if you have the alerons and covering removed the conversion is simple.just use some light ply and 1/4 square balsa to make servo trays in between the wing bays on equil distances on either side of the wing,usueally about 4 bays out or middle of each side of wing.you will have to make holes for the servo wireing if there isnt access through the ribs.i would use smaller servos due to weight.i did the same thing on a 4star 40,and pt60.both were glo fuel though.
I had considered that as far as weight, but the addition of the spare servo won't throw me off by much, I was already overpowering the plane by a small amount(I have a power system capable of handling a 5# or so 3-d aircraft ) and one s3004 wont make to much difference I don't think, and I would like to have flaperons and an air brake function with it. I believe all the ribs through to the root have holes on them, I'm going to attempt to install paper tubes for convenience sake and find out.
