RCU Forums - View Single Post - Reciver battery
Old 06-19-2007 | 04:32 PM
Bad_Daddy's Avatar
Bad_Daddy
Default RE: Reciver battery
It will be a YES if you get a voltage regulator to put inline between the battery and the receiver. These are small units, the size of a 15A ESC or less, and add about the same amount of weight.
If you don't regulate the voltage, the answer will be NO, because you will let the "magic blue smoke" out of your receiver within a minute of plugging the battery in.
Your choice.
